Cannot Initialize B2C2 MPEG Filter
arni
I USE xp an skystar since a year whith DVBViewer and progdvb and since a month
i can't do anything with i tryed everything i have good signal but no screen no sound
help me please
Did you already try to reset the SS2? Go to device manager, deactivate the B2C2 Broadband whatever (network cards), and re-activate it.
yes i tried this and evrything else but no reults and this in 2 different computer same problem good signal but nothing
  • 3 weeks later...
i have the same problem. what to do now?
was working well over an half year, and no good signal but no picture and the error box "cannot ..."
tried every PCI slot, no use of diseqc, ...
There exist no lock since driver 4.28
Please rename your channel.dat in DVBViewer main directory to channel.dat.bak and make a new channelscan and tell us which tv stations you foung.
  • 1 year later...
I have the same problem and do all that you said before... But nothing happens!
Can I understand what's the matter? Is this hardware problem or software?
