ddichiera Posted September 8, 2011 Posted September 8, 2011 Hi everyone, I've been unable to get streaming to work via the webserver for quite some time now. When I first got the streaming to work (last year), it wouldn't stream to the WAN, but Tjod made a suggestion about the firewall which worked. see here: Webserver no access via wan. This time around I'm unable to stream even over my local network. I've tried turning off my Antivirus (Kaspersky) and the firewall is not active, but I still can't get it to work. VLC reports that it can't open port 3335. BTW: I have two PCs with the same problem. One has been upgraded to 1.9 the other is still on 1.8.0. Dominic
Kiwi_Tim Posted September 9, 2011 Posted September 9, 2011 Not sure what the problem is, but at a guess try configuring port forwarding in your router so that the appropriate ports are being forwarded to the ip address of the DVBV server. Worked for me. Had to configure port forwarding for ports 8089, 3335 and 7522. Tim New Zealand
ddichiera Posted September 9, 2011 Author Posted September 9, 2011 Thanks Tim, I already have 3335 forwarded, but actually I can't even stream from within my network at the moment. I can't imagine what, apart from AV, could be blocking it. I turned that off, but it still wouldn't stream. It hasn't worked since the last couple of updates to RecServ.
ddichiera Posted September 11, 2011 Author Posted September 11, 2011 And here is VLC's log output (verbosity=2) main debug: processing request item http://192.168.0.36:3335 node Playlist skip 0 main debug: resyncing on http://192.168.0.36:3335 main debug: http://192.168.0.36:3335 is at 0 main debug: starting new item main debug: creating new input thread main debug: Creating an input for ' http://192.168.0.36:3335 ' main debug: thread (input) created at priority 1 (../.././src/input/input.c:220) main debug: thread started main debug: using timeshift granularity of 50 MiB main debug: using timeshift path 'C:\Users\Dominic\AppData\Local\Temp' main debug: ` http://192.168.0.36:3335 ' gives access `http' demux `' path `192.168.0.36:3335' main debug: creating demux: access='http' demux='' path='192.168.0.36:3335' main debug: looking for access_demux module: 0 candidates main debug: no access_demux module matched "http" main debug: TIMER module_need() : 0.000 ms - Total 0.000 ms / 1 intvls (Avg 0.000 ms) main debug: creating access 'http' path='192.168.0.36:3335' main debug: looking for access module: 2 candidates access_http debug: http: server='192.168.0.36' port=3335 file='' main debug: net: connecting to 192.168.0.36 port 3335 qt4 debug: IM: Setting an input main warning: connection timed out access_http error: cannot connect to 192.168.0.36:3335 main debug: net: connecting to 192.168.0.36 port 3335 main warning: connection timed out access_mms error: cannot connect to 192.168.0.36:3335 main debug: no access module matching "http" could be loaded main debug: TIMER module_need() : 10007.000 ms - Total 10007.000 ms / 1 intvls (Avg 10007.000 ms) main debug: waitpipe: object killed main error: open of ` http://192.168.0.36:3335 ' failed: (null) main debug: thread ended main debug: dead input main debug: thread times: real 0m10.009572s, kernel 0m0.000000s, user 0m0.000000s main debug: changing item without a request (current 0/1) main debug: nothing to play qt4 debug: IM: Deleting the input main debug: TIMER input launching for ' http://192.168.0.36:3335 ' : 10030.000 ms - Total 10030.000 ms / 1 intvls (Avg 10030.000 ms)
janip Posted September 17, 2011 Posted September 17, 2011 I can't stream too. Now i have fresh win7 64bit installation and offcourse latest recservice. I can see VLC.exe in taskmanager, but vlc does not do nothing. (0% load) All works ok earlier. Nothing change router and i try to stop win7 firewall.
janip Posted September 19, 2011 Posted September 19, 2011 Ok, streaming works again with 1.9.2 Beta. Do you have any idea, why streaming does not stop when i press browser stop button? I have to start new stream, when i want to stop vlc. That is old bug at least me and now it happens with fresh win7 installation.
