Wrong recordings duration time?
janip
http://japesone.kapsi.fi/gallery/Images/kavija_kuvat/Wrong_time.JPG
http://japesone.kapsi.fi/gallery/Images/kavija_kuvat/mpc.JPG
File is 55min long.
Dvbv show time allways correctly, but all other software shows wrong duration time maybe half of my recordings. vlc, xbmc, mpc...
What could be wrong? Recording is ok, Discontinuities: 0
Could it be my raid0 disk issue? There is a lot hardware ECC recovered errors.
Ok, i check file with mediainfo. Header is ok, those other players calculate duration wrong, but why?
Edited by janip
different calculation methods..
only if you'd count the video frames you would be sure to have the exact play time. But then the entire fle hast to be analyzed first ;)
But some of those .ts files is ok. I think there is something wrong in recordings or that raid0 disks.
Maybe dvbv use only that header info?
I don't care exact same play time, but 16h recording is little bit too long. :)
Edited by janip
