No signal - Avermedia DVBT A850
olive_69
I use DVBViewer 4.9 and i can't get a signal with my Avermedia Volar Black HD DVBT (A850), my card works with the Manufacturer Software (AverTV) although.
I try to reinstall drivers, DVBViewer and A/V codecs but none of them have solved the problem.
I use :
* Windows 7 x64
* AVerTV Volar Black HD(A850)
* Microsoft DTV A/V codecs, FFDShow codecs.
Any ideas??
Thanks
  • Like 1
Member Area abd download the "Hardware Database Update". Workarround you can see on right side by "Information"
Useless in this case. DVBViewer has already detected the device correctly as AfaTech AF9015 compatible.
Please describe more in detail what you have tried, and in which country/region you want to receive DVB-T.
Oh that´s correctly..sorry...my mistake
I fix it with this tip. But DVBViewer crashes sometimes at 1-2/h. I'm testing it a few days before posting the log file.
Thx!
