Now that version 5.0.0.0 in the offing!
fundom
I would request the following "conveniences" in the next V.5.0.0.0
1- Detection of 3D stream be made automatic (like in PowerDVD Player etc.). AND if that is not currently possible, then at least Anaglyph shader ON/OFF button in the tool bar would be very handy.
2- Sometimes life-like colors become more important than 3D anaglyph viewing. Is it possible to have a shader type filter which would allow a full screen MONO view (left or right)from a stereo stream?
Thanks & regards,
Creating such a shader is extremely simple - therefore i made the pixel shader editor (http://www.DVBViewer.tv/forum/topic/40907-pixelshader-editor/).
All you need is to change the red,green,blue values in order to draw just the left or right image to the screen:
sampler s0 : register(s0);
float4 p0 : register(c0);
#define width (p0[0])
#define height (p0[1])
float4 main(float2 tex : TEXCOORD0) : COLOR
  tex.x = tex.x / 2;
  float4 l = tex2D(s0, tex);
  tex.x = tex.x + 0.5;
  float4 r = tex2D(s0, tex);
  float red = l.r;
  float green = l.g;
  float blue = l.b;
  return float4(red, green, blue, 1);
if you keep it more simplified try this:
  tex.x = tex.x / 2;
  return tex2D(s0, tex);
Christian
Swiftness with which suggestion handled & results achieved are amazing! Bravo, hackbart!
