TBS Q-box S3 USB and Diseqc 1.1
wavefrontier
My TBS Q-Box S3 USB is not working with Diseqc 1.1 and I can watch only a few transpoders . The satellite signal comes from a multischalter and my satellite receiver works with both satellites (Astra and Hotbird) only when it is configured to Diseqc 1.1. When the receiver is set to Diseq 1.0, I can watch only a few transpoders from Astra.
I am using 1.0.0.2 WIn driver for S3 (1.0.0.4 is not working) and DVBViewer (now upgraded to 4.90). I have tried all the possible options with Extended Diseqc as well, committed and uncommitted swich and no luck.
I would appreciate any tip on how I could find a solution and make my Q-BOx S3 running with Diseqx 1.1.
Can you provide the support.zip information?
Christian
PS: What happens if you open the hardware.xml (located in the settings) and change the value vendor from 18 to 13?
I changed the value vendor to 13 and it worked out! Thank you very much for your help!
