Kelvin Left Posted September 21, 2011 Posted September 21, 2011 (edited) I am using the webinterface to stream the TV to laptop. I can see all the digital TV channels flawlessly. Then I tried to add the hard subtitle to the video stream. So I added scodec=dvbs,soverlay to webstreaming.ini like this. [Preset.0] Name=LAN VLC Muxer=3 UseVideo=1 VCodec=7 VRate=768 VSize=0.75 UseAudio=1 ACodec=2 ARate=96 AChannels=2 UseHardware=1 Deinterlace=1 Output=http{mux=[muxer],dst=[iP]:[Port]/} :sout-all :sub-language=any Outputlink= transcodewrapper=transcode{[AV]}: Audio=acodec=[acodec],ab=[abitrate],channels=[achannels] Video=vcodec=[vcodec],vb=[vbitrate],scale=[vscale][deinterlace],scodec=dvbs,soverlay Videocodecspezific= However, there are no lucks to see the subtitle. Then I checked the svcdebug.log and found the input stream located at http://127.0.0.1:7522/transcode/channelstream/4.ts However, I found the subtitle was not in the video stream. Then I tried direct streaming. The subtitle track was still in the video stream. http://127.0.0.1:7522/upnp/channelstream/4.ts Can you help to check how I can recover the subtitle track in the "transcode" stream? Thanks!! Edited September 21, 2011 by Kelvin Left
