Does multi-tuner DVB s2 card not work with DVBlink
Guest aron85
I owned a TBS 6981 DVB S2 dual tuner card and something wrong with the DVBlink while working
1.The card does not work together with DVBLink on the my system
2.The problem is that the card goes into a state of black screen after being active for some time.
Does multi-tuner DVB s2 card not work with DVBlink?
Mulit-tuner card woks well with DVBlink,maybe you should update the latest driver of TBS6981 from TBS download center.
Edited by amor
