wikings1 Posted September 26, 2011 Posted September 26, 2011 Hello i wonder if i can combinate usals and manual sattelite positions in DVBViewer 4.9 Some sattelites ned fine tune so thats why i asking regards wikings1 Quote
QBox User Posted September 26, 2011 Posted September 26, 2011 The TransEdit utility allows you to select, for each satellite, one of 3 options for dish motors angular position (similar to USALS) Preset position (Goto n) Extended sequence - allows either of above to be repeated, with delay The Positioner Console lets you make fine adjustments and store positions, while the Analyzer window displays signal quality. Quote
wikings1 Posted September 26, 2011 Author Posted September 26, 2011 oki god i use angular right now do i have to use the wekest signal (Frequense) to get the best position of the dish? And any one know wish ones to use from 30w to 30E I am from sweden Regards wikings1 Quote
QBox User Posted September 26, 2011 Posted September 26, 2011 Any frequency should give a similar response, though a weak one may have a narrower maximum point. A strong signal might show a maximum over 10 steps on my motor, but from the East/West points where it starts to weaken, I can judge where the mid-point is. Quote
