Ghigo Posted September 28, 2011 Posted September 28, 2011 Hello. I wanted to know if you can configure the "recording service" so that the EPG update every 2 or 3 hours instead of 12 by default. Unfortunately in Italy the major television broadcasters transmits only the current program epg and the following, but not a daily guide (only a few stations do). Quote
MaxB Posted September 29, 2011 Posted September 29, 2011 You should take a look at the Wiki! Example: Internal Tasks You can create so many Timers as you should need for the EPG-Update... Quote
