Graphic card fot HTPC
Knut
Im gonna buy a new graphic card for my HTPC.
I also have a TV card in my HTPC.
What type of card is recomminded????
Is have to fit PCI Express, and should be ready foe 3D.
I prefer a silent card.
I have Windows 7 64bit.
What type of CPU do you have? At the moment I run my PCs with the integrated card in the Intel Core CPUs and the image quality is quite good. Otherwise I would go for a passive ATi 6450
Edited by blasgl
CPU: Intel Core i3 Dual Processor i3-530
This is my other hardware:
Silverstone SST-LC17B HTPC
Vifter: 2x 80mm Bak, 2050 RPM, 21dBA
Intel Core? i3 Dual Processor i3-530
Dual Core, 2.93Ghz, Socket 1156, 4MB, 73W, Boxed
ASUS P7H55-M, H55, Socket-1156
DDR3, m-ATX, GbLAN, HDMI, PCI-Ex(2.0)x16
Corsair Value S. DDR3 1333MHz 4GB CL9 Kit w/2x 2GB, Unbuffered, CL9-9-9-24, 240pin, 1.5V
Corsair VX 550W PSU ATX 12V V2.2, 80 Plus, Standard, 1x 6pin, 1x 6+2-p
Lite-On Blu-Ray Reader IHOS104-37 Blu-Ray DVD-ROM, Sata
CyberLink DVD Suite - w/Blu-Ray support Windows 7 OEM, PowerDVD 9 BD+ 6CH, PowerProduc
HIS Radeon HD 5450 512MB DDR3 PCI-Express 2.0, DVI, native-HDMI
Microsoft Windows 7 Ultimate EN OEM, 64bit
I think you are all set. You already have a "Intel HD Graphics" that you can use straightaway and a "Ati HD 5450". Why do you think you need a new card? Games?
I have some pixel fault(interuption) comming up on HD channels waching TV.
So maybe it can be the buffering gets les and les, and result in a pixel fault.
It's looks very good when i watch TV, but somtimes i got this interuption.
I have posted the issue another places her to, but i dont knoe what to do.
My 512MB card should be god, but i have to start some place to see if its getting better.(im a bit out of things to do :-) 9
