Quick question
Bjur
Hi a quick question. Is it possible to only install recording service as a standalone without DVBViewer_
Yes
But why?
No, it isn't. You have to install the DVBViewer first. But you don't have to use it.
Thanks for the answer.
@McenterFreak: I only wanted the recording service, since I'm on WHS 2011 and don't use it for TV.
extra question: Lars_MQ: Can you tell me if there's a fix for streaming recordings with 64 bit systems to Ipad 2?
there is no fix needed.It does work without problems, if you use the correct ffmpeg version (as stated in the wiki).
