No Hardware Found
Rodrigo Pelle
Hello folks...
I've just bought the DVBViewer and I realized how wonderful is...
I know my Tuner Card Pyxelview Hybrid USB is fully compatible with DVB but I'm not getting this to work...
It shows in DVBViewer settings on 'Hardware' tab
Conexant Polaris BDA Tuner
Any clue?
Thanks in advance!
Edited by Rodrigo Pelle
check if other programs use the card (MCE, MP etc). And make sure you use the right channellist (no installing a SAT list for your -T card).
If in doubt try scanning the channels with transedit from the membersarea. :)
First of all thanks Lars for trying to help me...
I've downloaded the TransEdit and it's funny cause when I press to scan it detects HD channels here and preview normally...
I export list to 'Transponder' folder but when I open DVB the same problem occurs.
