bl4ck Posted November 12, 2011 Author Posted November 12, 2011 (edited) delete Edited July 19, 2012 by bl4ck
ASAKURA Posted November 12, 2011 Posted November 12, 2011 XBMC PRE-11.0 + DVBViewer 4.9 How did you do this????
arbist2005 Posted November 15, 2011 Posted November 15, 2011 (edited) XBMC PRE-11.0 + DVBViewer 4.9 How did you do this???? use plugin launcher XBMC to execute DVBViewer.exe and config your remote to work with XBMC and start DVBViewer in full screen Edited November 15, 2011 by arbist2005
bl4ck Posted December 5, 2011 Author Posted December 5, 2011 (edited) delete Edited July 19, 2012 by bl4ck
bl4ck Posted January 18, 2012 Author Posted January 18, 2012 (edited) delete Edited July 19, 2012 by bl4ck
tomas.jurksas Posted January 19, 2012 Posted January 19, 2012 About that maybe ? [removed] § 13 Do not ask for or discuss plugins for descrambling/decrypting pay-tv or key-codes. Although the DVBViewer Pro provides full pay-tv functionality it must only be used in combination with a valid subscription of a pay-tv provider, a tv-card/box featuring a "conditional access module" (CAM)and/or the corresponding "common interface" (CI) with a smart-card. This applies regardless whether software-descrambling is allowed in your country or not. http://www.DVBViewer.tv/forum/index.php?app=forums&module=extras§ion=boardrules
