Gugaoforums Posted October 13, 2011 Posted October 13, 2011 Hello developers! moderators! and hard users! can you tell for us what means: vbi pdc ? eit runing status ? rec. title ? rec. event ? monitor pdc descriptor ? this is really important to use auto timer! I dont find this information in wiki page.. thanks for all information
Tjod Posted October 13, 2011 Posted October 13, 2011 vbi pdc ?eit runing status ? monitor pdc descriptor ? http://www.DVBViewer.tv/forum/topic/19629-recordingservice-beta/page__view__findpost__p__344581 rec. title ?rec. event ? Add: Webinterface/Auto search: You can now select if the auto search should compare it's results with the recordings db (Title and/or Event). If a result is found in the db the auto search will create a DEACTIVATED timer. For this to work, the recordings db has to be up to date and all recordings must be present. http://www.DVBViewer.tv/forum/topic/19629-recordingservice-beta/page__view__findpost__p__337334
Gugaoforums Posted October 13, 2011 Author Posted October 13, 2011 hello friend! it is really interessant if someone put this information in wiki page thanks for your information!
