Using auto-record search
Gugaoforums
Hello someone can give some information to us about auto-record search?
I'm add one program
search for ( program title )
search in [v] title
[v] Add to Auto-Record search
Check against [ ] Rec. Title [v]Rec. Event
so the search mark all programs title but mark the duplicates and reprises etc..
how to do to not record reprises?
the event and description is the same! why is marked to record?
can someone create one regular expressions to not record reprises?
thanks for all!
thanks friend!
I'm a fan of DVBViewer! but recording service dont get much attention from developers :(
now show [ ] Timer Name in search preset
what information timer name search for in epg?
what meas activate timer name in check against???
For example if you have a 7 day EPG and the show "Mythbusters - Episode 12" occurs 3 times during these 7 days, you only want to record the first occurence cuz the other two are re-runs. So in other words if you check "Timer Name" in the Mythbusters searchpreset the Autosearch timer will deactivate the two re-runs and only the first "Mythbusters - Episode 12" gets active status and will be recorded.
