neophyte Posted October 15, 2011 Posted October 15, 2011 Hi I'm entirely inexperienced in using XEPG (excellent work btw!) and hence am probably missing something glaringly obvious, but I can't understand - nor do anything to correct - what seems weird behaviour. I'm grabbing schedules from two sources using XMLTV. There's no problem with one source (fi_sv) but with the other (se_swedb) the resulting epg is inconsistent across the channels: one channel is truncated to only the first part of the first day (of five days). I'm attaching the .xml file containing the latest grab and from this it can be seen that all channels have the same programme info covering the same days. Yet for TV4 only the first two programmes for the first day appear in the epg, whereas all the other channels' schedules are complete for every day. What can be causing this to happen and what can be done about it, please? SVT.zip Quote
bogdan1980 Posted October 18, 2011 Posted October 18, 2011 salut, you need to post this info here: http://www.DVBViewer.tv/forum/topic/20539-xepg/page__st__660 OR ask an admin to move your info there. Quote
