Slow OSD
rdg
Hello,
When I browse my photos and my videos OSD is slow. Same with the slideshow. Is it possible to have an OSD faster?
ATI HD / EVR Custom / PowerDVD Filter 11
1920*1080@50hz
I am the only one with this problem?
I do not think ...
For example, when there are many photos (> 200) - > DVBViewer and remote control are very slow
Thumbnail generation at first start. You can also use list-mode or wait if generation is completed.
ok but XBMC or Windows Gallery are not slow during the generation of thumbnail.
DVBViewer is a great DVB Player but the HTPC mode is not efficient.
Edited by rdg
  • 3 years later...
I'm testing if DVBV works on my machine. Initially it seemed to work fast, then - after tested mosaic function on OSD - everything went very slow, particulary OSD and fullscreen functions. It continued after reboot and still it does.
While reinstalling all the program, I wish obtain your help...
svcdebug.log
