List of command line parameters?
jb238
Is there a list of command line parameters for DVBViewer? I'm looking specially for parameters to
- Change channel
- Start recording
- Stop recording
- Exit the program
Change channel
With DVBViewer Pro (not with TechniSat Edition). See here.
The rest and a lot more can be done with an additional tool, that receives command line parameters, converts them to Windows messages and passes them to the DVBViewer.
  • 8 years later...
[#10343] We could not determine which topic you were attempting to view.
can anybody tell me more about the "additional tool" ?
Dunno if Griga refer to those, but in "tool" Member's area section there are a "Channel Shortcutter" and a "Commandline Starter Plugin"...
:bye:
@Griga: Dein Link unter "additonal tool" funktioniert bei mir nicht und führt nur zu einer Fehlermeldung
Viele Grüße
Webturtle
  • 3 years later...
Please can somebody tell me what the existing command line switches are.
-c I saw the link above so I know how to use this one
-i This exists [the application uses it] but I not been able to find out what it does by experimenting with it
-m this seems to minimise the application
I just want to know what exists so I can decide if any of them are useful for me. If these ones existed I would definitely make use of them,
- one that opened the application with its EPG already showing
- one that opened the application with sound muted [i'd use that in conjunction with the EPG command line switch]
They are currently only in the German Wiki
http://de.DVBViewer.tv/wiki/Kommandoparameter
-i prevents the DVBViewer from executing the following command line switches if it is running.
-i -c will start the DVBViewer without playback but will not stop the playback in a running DVBViewer instance.
-x[number] is the one with most power the number is from the actions.ini (DVBViewer program folder)
-x25 -x37 for mute and opening the EPG window
  • Like 1
Tjod - Many thanks. The muted EPG switches are very handy for me and I will work my way through the German list to see what else I can learn.
