The One Posted October 20, 2011 Posted October 20, 2011 (edited) Hi Guys, Hope all is well. I have DVBViewer running as my local server. I also have a CCTV software running on the same machine. However the software that is supplied with the card is terrible. It would be excellent if DVBViewer could handle CCTV feeds so no need to change software. The card has a BDA based driver so can be detected under DVBViewer model? I would love to hear what you guys think. Card details below. WAPA PCI Express http://en.wapa.cc/html/Products/Video_Capture_Card/2011/0902/10.html Thanks Edited October 20, 2011 by The One Quote
Griga Posted October 20, 2011 Posted October 20, 2011 DVBViewer is designed for BDA drivers delivering a transportstream according to ISO/IEC 13818-1. It can't (and won't) handle analog sources. Quote
The One Posted October 20, 2011 Author Posted October 20, 2011 (edited) Hi Griga, Just double checked and the card is not BDA based just Capture DVR card. Saying that could or would there be a workaround. Such as an add-on to source filter to support capture cards? or maybe able to connect to web streaming feed? Maybe a add on to the IPTV interface? etc? Would love to hear your thoughts. Thanks for your time Edited October 20, 2011 by The One Quote
