Radio Stations UPnP problem
remlap
Hi, VOA on Hot Bird often uses both channels to broadcast two stations in Mono on a Stereo channel, if I set the station to left or right channel on DVBViewer I of course only get that channel, but is this possible on UPnP using the recording service?
Edited by remlap
Yes. Your UPnP player just needs to be able to select between the streams.
I cant because its a wifi radio, no option to.
Well, there is no way to filter out only the left or the right channel without completly de- and encoding the stream. And sorry no, that's for sure never gonna happen for the UPnP server part.
Thanks for your replies Lars I appreciate them, guess I'll stick to listening to VOA online :)
If you're curious what I have working for awhile..
Edited by remlap
