fxv1 Posted October 23, 2011 Posted October 23, 2011 Looking at DVB Source I notice I get "PCR/PTS Gap(4)" errors. Any idea what these errors means and how to correct ? Does the PTS Latency value affect the amount of discontinuities ? The above is on a DVB-S2 HD channel (BBC1 HD). Quote
fxv1 Posted October 23, 2011 Author Posted October 23, 2011 Adding another picture to show differences between two sources DVB-s2 and DVB-t2. DVB-t2 does not suffer from these errors. Quote
Griga Posted October 23, 2011 Posted October 23, 2011 Does the PTS Latency value affect the amount of discontinuities ? No. They are caused by bad reception or hardware/driver issues. AzureWave AD-SP400 DVB-S2 devices are known for it, at least in combination with certain mainboards. PCR/PTS Gap errors can occur as after-effect. Quote
fxv1 Posted October 23, 2011 Author Posted October 23, 2011 No. They are caused by bad reception or hardware/driver issues. AzureWave AD-SP400 DVB-S2 devices are known for it, at least in combination with certain mainboards. PCR/PTS Gap errors can occur as after-effect. Thanks Griga. A bit strange I do not get any of these or discontinuities errors on ITV HD using same hardware,problem seems to be specific to DVB-S2. Is there any setting that would help with this problem ? Quote
