Laserwave Posted October 27, 2011 Posted October 27, 2011 Has anyone managed to enable DXVA on the newer CoreAVC (3.0 and later) with DVBVPro? It doesn't seem to work (Win7x64 - ATI 5670). Quote
Laserwave Posted October 27, 2011 Author Posted October 27, 2011 Seems it's a CoreAVC issue falling back to software decoding when the DVBViewer Filter is used, instead for example, the Haali splitter. Quote
nuts Posted October 27, 2011 Posted October 27, 2011 (edited) Maybe there will be a fix in CoreAVC 3.1 http://forum.doom9.org/showthread.php?p=1529458#post1529458 Edited October 27, 2011 by nuts Quote
Laserwave Posted October 28, 2011 Author Posted October 28, 2011 Thanks nuts. I could try to use another splitter with DVBV but I'm not sure how - will probably wait for a CoreAVC update. Quote
nuts Posted October 28, 2011 Posted October 28, 2011 For LiveTV you have to use DVBViewer sourcefilter. For other mediafiles you can disable DVBViewer sourcefilter: options/directx/DVBViewer filter Quote
