laden0868 Posted October 29, 2011 Posted October 29, 2011 (edited) Hi, i'm from Hong Kong, and just update from DVBViewer 4.5, recording service 1.6.2 beta to DVBViewer 4.9, recording service 1.9.2 beta. The result is : the direct stream function ok! the Embedded function NOT ok! both direct stream and Embedded set off, hardware decode set on, choose H.264 , mp3 decode, NOT ok! all other setting was the same as I using DVBViewer 4.5 and recording service 1.6.2 beta, but it's worked fine with those version.... Should i uninstall all the related software again? vlc player, DVBViewer and recording service? And i want to ask which version of the vlc player and the ffmpeg that i need to install that can match the DVBViewer 4.9 and the lateset version of recording service..... P.S : Did any brother everythings work perfectly on dvb4.9 and rs1.9.2 SHARE YOUR CONFIG AND THE VERSION WHAT U R USING! Thx all brother Edited October 29, 2011 by laden0868
Lars_MQ Posted October 29, 2011 Posted October 29, 2011 use the current version of VLC. This has been changed month ago.
bogdan1980 Posted October 29, 2011 Posted October 29, 2011 ffmpeg, is here: http://tripp.arrozcru.com/builds/ffmpeg-18639.7z read here more: http://en.DVBViewer.tv/wiki/IPhone/iPod/iPad_Support ( read the instruction here to know what to do with ffmpeg) embedded not working for me also, with any vlc version. Transcoded and direct stream work.
laden0868 Posted November 5, 2011 Author Posted November 5, 2011 (edited) embedded not working for me also, with any vlc version. Transcoded and direct stream work. Thx for informations brother... After i tested, now both embedded and not embedded are work perfectly. I just provide my installation step .... 1. First i installed vlc 1.11 (the latest version), during the step of installation of vlc, you need to choose Fully installation 2.install DVBViewer 4.9 important! In my case, i need to install it fresh, if u have older version of DVBViewer in your system, i suggest u better uninstall it "completely" ! 3.Finally install recording service 1.9.2 All of the setting i was follow the instruction, Done! Edited November 5, 2011 by laden0868
laden0868 Posted November 5, 2011 Author Posted November 5, 2011 Now i have some another questions... the recording service have a option "web config", I have take the guess account, and set the password and user name for admin and guess, i think, that means the recording service can serve at lease two user ,both streaming, and watching difference channel, is that correct? (my tv card have two tunner!) i have try to use two account to login to port 8089, account "A" , i stream to port 3335, then i use VLC play back http://myip:3335 ok, embedd are ok too. then i haven't stop this streaming, i use another computer login to 8089, use account "b" then choose to stream another channel to port "3336", then use vlc to play http://myip:3336 , doesn't work! then i play http://myip:3335 again, it stopped. then i play http://myip:3336 again, it worked! I want to ask is that recording service support multi user? how many?
bogdan1980 Posted November 8, 2011 Posted November 8, 2011 laden, here is mine: DVBViewer 4.9, rec service 1.9.2: i start DVBViewer on channel BBC for example ( from transponder A) enter webpage, my ip http://192.168.0.198:8089/, go to channels from transponder A, BB1, stream it with VLC now i want to stream from BBC2, with vlc, but VLC crashes. I use mediaplayer, it open the stream. Conclusion, i could stream 2-3 channels in the same time with direct stream, from channels that are on the same trasnponder. I open one stream with VLC, second with mediaplayer, third with winamp. I test this with 1 single dvbc tuner, right now in the house i only have one tuner.
laden0868 Posted November 10, 2011 Author Posted November 10, 2011 thx for reply bogdan1980! update my test.. Now i finger it out , iphone work perfectly. android phone default brower and dophine brower can't see the stream, need to open the link on another stream player.... I use iphone Safari, must be log into http://yourip:8089/iphone, it will work perfectly, change channel ok. when i use android log into http://yourip:8089/iphone, it can't see the stream on the web page, and i open the link on another stream player, still not working.... and i open myip:8089, start the stream with emb, then open it with vplayer, its work..... so, the result is, android not so compatible in html5, with their default brower and dophin brower...... iphone haven't any problem, work perfectly.
