Integration with XBMC PVR
Well time to be honest. XBMC is without a doubt an exellent software for fileplayback, even if it's hogging the CPU to much with its interface (in my oppinion).
BUT it will not work with real DVB as it is now. It's way to much centered on the "file" aspect and I am sorry to say that I have serious doubts you can simply write some plugin to "convert" it to a useable LiveTV application. The SAT>IP aspect needs a lot of DVB processing and XBMC simply does not provide this...
That's the reason behind the PVR integration. XBMC doesn't care about the hardware because that's the backend task (in this case, the DVBViewer Recording Service)
HOW-TO:Watch TV in XBMC
Yes, you can and it's really simple even with the DVBViewer API shortcomings :( Check out the vuplus addon and you'll see that it's pretty trivial to add DVBViewer support with it as a code base.
As I said above, XBMC doesn't care about that.
Right now I'm using XBMC with DVBViewer. I can watch Live TV with EPG, add and edit timers, view and delete recordings and even check the signal strength...
Edited by A600
Of course it's possible if you code the PVR ;)
It isn't ready for a release but someday it will be.
Well, it sounds that your code is ready for release. So do it already! :)
I am also playing around with XBMC currently and I am not totally sold on it. Over the years I got used to the flexibility and extensibility of DirectShow (and even the quirks of it ;) ). It is giving me a hard time to imagine how to live without it. The usability and ease of use of XBMC are great though. AirPlay works out of the box with my iPhone 4 for video, photos and music :) . I am just wondering right now whether XBMC does all the things that are important to me. Due to its platform independence I am sure that there are lots of restrictions and imperfections.
I`d love to use XBMC as Frontend for the Recording Service.
I´m looking forward for a beta ,-)
It's too hackish and being XBMC open source, there is no way I can release it the way it is now.
Why are you advertising for something that you do not publish anyway? I think a lot of users would pay money for this ...
+1
Oh COME ON...be happy something is finally on the way!!
Do not misunderstand me. But we are all very impatient. I hope that it will be released soon. Can we expect this year with a release date? If you could give more information (like videos or screenshots), surely many would also be willing to give a small donation.
A600 we wait for.
....a ver esa release que seguro que somos muchos los que la esperamos :o
OMG...three years and my first post....sorry
Edited by Paranosh
I would donate money, when you can accelerate the production...
First version released. Get it from this thread at the XBMC forums.
Thanks :bounce: !!
Muchas gracias A600. Deseando llegar a casa para probarlo.
Un saludo.
Nice that you released it, so far all it did is make my XBMC crash though...I can start XBMC, but as soon as it has loaded it crashes with multiple errors...will check the logs and see what is wrong.
UPDATE: Itr works fine, my XBMC PVR build was too old, installed the latest nightly and all is well.
THANKS!!!
Edited by CommanderROR
Thank you very much! It works like a charm..
..fantastic!
..thanks a lot for your work.
Works already great!
hoto44
Works great on PC, however, it seems not to work on the Raspberry Pi (running raspbmc RC4 with latest nightly from 02.09.2012).
I posted the error on the XBMC forums and will keep it there.
Thanks for your hard work. I'm sure it'll be even better once it has gone through some alpha and beta stages... ;)
It's already amazing for a version 0.1.0!
darf ich mal kurz fragen was das ist?
Kann man jetzt mit XBMC über DVBViewer fernsehen?
Danke
I may even ask her what is it?
You can now watch TV with XBMC via DVBViewer?
How is it OK?
Please in English
Thank you
Thanks :D
What does someone have it?
Is there evt a finished version of XBMC?
:D
Edited by power-dodge
you didn't read this thread ?
but of course I read it, understand it's not just ... :unsure:
'm Too stupid for that. :blink:
Thanks
Could we have a tutorial on how to configure everything 'cause so far all i get is "loading channels from clients" message then nothing
Thank you very much for this addon ;)
there is no configuration except IP adress of the Recording Service.
btw, the logos only are showed if the name of the png from the DVBViewer\Images\Logos\ folder is exactly the same as the channel name. Unfortunately, the DVBViewer API doesn't provide the logo names so I can't fix that.
Edited by A600
..not a big problem for me. Everybody who ist interessted, can fix that by themself..
..I enjoy your work very much.
Thank you! This ia great.
I have it running OK but a slight problem with recordings - I can see the list but when I select one, nothing happens, Running on a local PC with recordings stored on local HD.
Is this supposed to work or am I just being impatient?
Sorry - forget the recordings bit - started working all on its own.
Wow, finally a solution which deserved the name "Media Center". Thanks a lot!
I had trouble with my password for the Recording Service. It began with a colon ":".
The add-on got all data (like EPG), but wasn't able to play TV streams.
I think the add-on tried to open a stream URL like http://user::pw@127.0.0.1 in my case.
One colon too much?! :rolleyes:
regards
Mojo
Is the streamserver port correct (by default 7522)? In that case, I would try a pass without the ':'
Yes, all settings were correct.
It was only the colon at the beginning of my password.
How can I watch encoded channels? [removed]
Im legal DVBC subscriber...
§ 13
Do not ask for or discuss plugins for descrambling/decrypting pay-tv or key-codes.
Although the DVBViewer Pro provides full pay-tv functionality it must only be used in combination with a valid subscription of a pay-tv provider, a tv-card/box featuring a "conditional access module" (CAM)and/or the corresponding "common interface" (CI) with a smart-card. This applies regardless whether software-descrambling is allowed in your country or not.
http://www.DVBViewer.tv/forum/index.php?app=forums&module=extras&section=boardrules
