Latest TransEdit postioner doesn't work
omega88
I use SkyStar USB 2 HD CI on Win7 x64
I can scan and save channels correctly using TransEdit, also the motor moves when I scan on different satellites (preset positions)
but I cant control the motor using the positioner .
P.S positioner works correctly in TransEdit 3.5.4.0,
but it doesn't in any newer version (3.8,3.7,3.6)
Yes I'm using the latest driver "1.0.5.702"
I found newer driver "1.0.6.102" ( not on technisat.com)
but same problem and i got "no signal" on many transponders
I also tried using AzureWave bda driver since it's very similar ,but i also got the same problems as the "1.0.6.102"
so i'm back to "1.0.5.702" which is the latest official driver.
(Latest TransEdit postioner didn't work on any off this drivers)
Ok, your device has been detected correctly. Does the positioner console work if the analyzer is active at the same time?
I think I know what's wrong. Please try the test version 3.8.1.7 from the members area, beta section. The positioner console should now work stand-alone.
