Gugaoforums Posted November 9, 2011 Posted November 9, 2011 Hello! I have my htpc exclusive to DVBViewer i3 2100 4gb ram 2tb hd 2 cards tbs 6984 I have a lot of timers to record.. and some randoms times I get datarate 000 kbps the only way to get card recording again is: set tuners to not use in device manager in windows disabe card tbs 6984 affected wait 3 seconds.. reenable again tbs 6984 set to use card in configuration and start recording ok again what this problem happened? thanks for all help! support files is here http://www.multiupload.com/VG8I9IC91V
majstang Posted November 9, 2011 Posted November 9, 2011 This issue is probably due to a buggy driver for your TBS card...see this thread: http://www.DVBViewer.tv/forum/topic/47433-tbs-6981-dvb-s-dual-tuner-cards/
Gugaoforums Posted November 18, 2011 Author Posted November 18, 2011 hello friend! thanks for your repply I get the new beta driver from tbs but.. the driver dont solve the problem! four times I have this randoms errors.. the computer is always on.. and working best for 3 hours.. and stop receive stream.. I have to close program.. disable and reenable hardware.. always on again.. windows 7 x64 please help!
majstang Posted November 18, 2011 Posted November 18, 2011 Ok, then you probably have a faulty dvb-card.
