Rob66 Posted November 12, 2011 Posted November 12, 2011 (edited) I have installed OS windows 7 Ultimate TT-budget S2-1600 PCI bus 3, device 6, function 0 TT-budget S2-3200 PCI bus 3, device 7, function 0 DVBViewer > Option > Hardware > Small windows shows... TechnoTrend BDA/DVB-S Tuner (1) - selectable TechnoTrend BDA/DVB-S Tuner (2) - selectable I can select Tuner (1) or (2) but I can't APPLY this function is inactive. Even i press OK it will not select.. TT S2-1600 tuner is unreachable TT S2-3200 tuner is working perfect... Somebody have a advice how to solve this problem? Thks Rob Edited November 12, 2011 by Rob66 Quote
Griga Posted November 12, 2011 Posted November 12, 2011 I can select Tuner (1) or (2) but I can't APPLY this function is inactive. You are not supposed to APPLY this selection. You can change the settings of the selected hardware, and then you can APPLY. E.g. you may use the Status Dropdown List to let DVBViewer prefer a certain device. Quote
Rob66 Posted November 12, 2011 Author Posted November 12, 2011 Yes, i find my way. I using prefered to get control about my device. It is working now..... Thks voor your advice.... Rob Quote
