themaster1 Posted November 15, 2011 Posted November 15, 2011 (edited) By default when i open the file browser (htpchome > movies) the ListView option is highlighted and i'm wondering if i could tweak that to have the first file at the top highlighted instead. Edited November 15, 2011 by themaster1 Quote
Tjod Posted November 17, 2011 Posted November 17, 2011 This is defined in the OSD-Skin. If you open a OSD skin page and no element is selected. You can open the property's and there is the value DefaultItem. The ID ist the ID of the element which has the focus when you open the page. Quote
themaster1 Posted November 17, 2011 Author Posted November 17, 2011 I don't see where i can set this exactly please enlighten me.Should i edit the .xml in such case which one, also note i have the concinity 3d skin enabled Quote
themaster1 Posted November 20, 2011 Author Posted November 20, 2011 Somebody alive in this forum ? There is no "Default item" when i open whatever pageon the OSD so i need further assistance.... Quote
Gioxy Posted November 20, 2011 Posted November 20, 2011 Tjod already show you what to change if you want modify yourself a OSDSkin page; and to do that, you must use the apposite Skin Editor... Quote
