rif Posted November 26, 2011 Posted November 26, 2011 Attached a very simple shader that enable to see in 2D any emission in 3D: useful for people not having a 3D TV set but interested in watching an emission on a 3D channel... Enjoy ! 3D to 2D.xml Quote
ThulsaDoom Posted December 28, 2011 Posted December 28, 2011 Hi rif, thanks a lot for sharing this! It´s working great - just did a quick test with The Lion King (recorded from Sky 3D). Plays as smooth as the normal 2D version and i couldn´t see any loss in picture-quality due to the conversion. Quote
piit79 Posted July 27, 2012 Posted July 27, 2012 Thanks a lot! Allowed me to watch the Olympic Opening Ceremony on BBC HD - it was broadcast in 3D and I don't have a 3D TV yet Naturally there is quite a noticeable degradation in the horizontal resolution but that's an inherent limitation. Still much better than SD Pete Quote
Mr. Bun Posted July 28, 2012 Posted July 28, 2012 Just FYI: You should have been able to watch in (full resolution) 2D on BBC One HD - it's even on the same transponder as BBC HD. Quote
Shrubsole Posted July 30, 2012 Posted July 30, 2012 Thanks for this. Comes in handy with all the free Olympic 3D stuff flying around at the moment. Quote
b3h3m07h Posted August 5, 2012 Posted August 5, 2012 how do i use this file in DVBViewer. ive placed it into the shaders folder but what next? cheers Quote
Shrubsole Posted August 5, 2012 Posted August 5, 2012 Tune to a 3D channel or play a 3D recording. Options/DirectX and click on the box USE CUSTOM RENDERERS (If you don;t already) Right click on the picture and select View/shaders and then the shader of your choice. Switch the shader back to NONE to get normal viewing back. Quote
madsilence Posted August 12, 2012 Posted August 12, 2012 Which eye is this shader showing? only left or only right? Could you remake it for another eye.....Just needed, don't ask why 8-) Quote
dvbrewer Posted August 12, 2012 Posted August 12, 2012 Which eye is this shader showing? only left or only right? Could you remake it for another eye.....Just needed, don't ask why 8-) Left eye I believe (tune to a non 3D channel to see). Thanks for the shader rif, useful to a watch a near HD highlights prog (there was no 2D highlights except SD on red button). Quote
