Upnp channels show up but won't stream
gsi095
I found the DVBViewer upnp server via XBMC and added the channels as a upnp folder.
When I go to stream the channel it wont play.
Is there a something I need to do?
Dave
Hi gsi095,
should work, I mean I had the same issues a couple of months ago and the answer was: try
a newer XBMC version and I did. My conclusion was there are nightly XBMC builds around that are
working and others not. So it looked like an XBMC issue though....
cheers,
carsten
