LOF setting for Transedit 3.5.4
RW_
I need to know what the LOF setting for Transedit 3.5.4 for a universal LNB is.
I have tried the settings that come with transedit and a number of different combinations but cant get it to work.
I was using a standard LNB and the settings in transedit were 0-10750-11750 before I switched to a universal and it worked just fine.
Any help would be appreciated. :)
current version of TransEdit is 3.8.2
from the manual (also available ;) ):
The default values (9750/10600/11700) are appropriate for the commonly used Universal LNBs, that are able to receive two frequency bands (low and high, controlled by the 22 kHz tone). Do not change the values, unless you know exactly what you do.
  • 3 weeks later...
Hi Derrick
Thanks for your reply and sorry it took so long to get back.
When I first had the problem of Tras Edit not being able to read the signal after changing the LOF back to the orignal settings of 9750 10600 11700 Trans Edit just would not read it but after re booting the computer a couple of times it finaly did.
I do not know why.
But i am glad it finally worked. :)
