Avermedia Aver3D USB - Positioner in Transedit
rizik29
The Avermedia DiSEqC interface used by TransEdit/DVBViewer is only suitable for DiSEqC 1.0. Maybe AverMedia is providing a better one now - we have to find out, and that will take time.
However, you can try if the driver conforms to an interface used by other vendors. Open the file TransEdit.ini with a text editor (TransEdit must be closed) and change the vendor value in the [Hardware] section e.g. to 19. It will at least enable selecting your card in the positioner console.
