Nicholas Carlson Posted December 2, 2011 Posted December 2, 2011 I have the TBS 6928 with a Jolly 1.01 CAM (technically identical to a Diablo 2.3). I use DVBViewer. I can view and also record encrypted channels correctly in the DVBViewer program. However, when I use the DVBViewer Recording Service, the channels only record properly when I have the channel tuned in the DVBViewer program. Otherwise, if the DVBViewer program is closed but the Recording Service tries to record an encrypted channel, the channel is not decrypted by the CAM and is thus not recorded properly. It seems that the DVBViewer Recording Service does not know how to activate the CAM in the TBS 6928, but only in the DVBViewer program. I have another computer configured with a FloppyDTV-S2 with the Jolly CAM. The DVBViewer Recording Service works perfectly with it, so I know that this is a problem that can be solved. Can you help? Maybe I don’t have the DLL installed correctly? Or is this something you still need to work out with DVBViewer? Thanks. Quote
