Cannot Get Electronic program guide to skin
Interplain
Hello,
I Have installed a skin to change the main windows of DVBViewer 4.9. The problem i have is that the EPG window looks as it did when first installed with the Blue and white Window. I had 3.5 installed and this was skinned with A Skin Called BlackFusion. I Installed The Same Skin to 4.9 and EPG the time line window Skin as gone.. And also the Items in the View Menu, Hide All And the remaining items below are Ghosted..
Any Ideas how to install a EPG Skin to the Timeline window
Thanks
