maurotb Posted December 21, 2011 Posted December 21, 2011 Hi, i have two problem: Into:i hanve one skystar hd2. I have imported fresh ini from kingofsat. Usals position is ok in settings. 1) If i make scan from DVBViewer, some channel not is found. 2) so,i have scanned some sat with my rotor. All is ok.With this,all channel are found. Now if i import scanned channel in DVBViewer, when i change channel, rotor move dish, i can see imagege for one second,rotor continue to move dish for some grades and i lost signal. Thanks Quote
QBox User Posted December 21, 2011 Posted December 21, 2011 If you scan in TransEdit, the channel will be stored with the default DiSEqC setting for the satellite. If you scan in DVBViewer, the DiSEqC settings have to be entered manually. You may find that channels scanned using DVBViewer have been stored with the wrong position/angle. I found some of mine were going to position 0. Always best to use TE for scanning a motorised system, I think. Quote
