motu828mk2 Posted December 25, 2011 Posted December 25, 2011 (edited) hi all Newbie here i buy an (Skystar 2 Express HD PCIe) with (DiSEqC 1.2 moteck SG-2100A H-H motor) ,but the motor not working with Goto angular and extended ...not working at all DiSEqC settings is possible to fix that problem ??? or must return the Skystar 2 Express HD back to buy another pcie card ?? and whats the best DVBViewer full Compatible PCIe or PCI cards with diseqc 1.2 support to buy ?? thanks for the support support.zip Edited December 25, 2011 by motu828mk2 Quote
Griga Posted December 25, 2011 Posted December 25, 2011 is possible to fix that problem ??? It works under Windows 7 with the current DVBViewer Pro 4.9, and in future versions it will also work under XP. However, making the TransEdit Positionier Console work is a bit difficult. Read more about it here. Quote
motu828mk2 Posted December 25, 2011 Author Posted December 25, 2011 thanks for the fast support/// also whats the best DVBViewer pro full Compatible PCIe or PCI cards with diseqc 1.2 support to buy ?? Quote
Griga Posted December 25, 2011 Posted December 25, 2011 also whats the best DVBViewer pro full Compatible PCIe or PCI cards with diseqc 1.2 support to buy ?? Please don't start another discussion about this topic, but join here. Quote
il diavolo epm Posted April 13, 2022 Posted April 13, 2022 It would be enough for me to start the engine? Quote
