dvd menu not working, win7
themaster1
It's the first time i try to play a "real " dvd today with a menu on Win7 , believe it or not nothing happen when i press on a link "play, chapter" etc...
I'm running Win 7 x64 and DVBViewer 4.9.0. I don't seem to recall problems with previous versions and Xp so i find it strange.
Another thing strange is that there is no sound.
Edit:
Well it seems i found out, i didn't enabled a few things in DVD Options (audio renderer, ffdshow etc...), dvd, but there is something strange still: the EVR don't seem to be supported with the dvd menu , only overlay is that the correct behavior ?
Edited by themaster1
It depends a lot on the used codec. So far i had the best results with the Microsoft codec regarding menus.
