Knut Posted December 30, 2011 Posted December 30, 2011 Hi, I had a terratec card with ci modul etc. Was struggling for a long time with some pixel fault on HD channels (only somethimes). I got a new tv card from Digital Devices during the Xmas, and know the pixel faults are gone. But i also got a Samsung LED Smart TV UED8005. I tryed the cam into the TV, and the picture looks better then. It looks like the picture is running smoother. I want of course to use DVBViewer instead. On DVBViewer it looks like the picture is jogging compared to the Samsung TV. It is someplace on my computer/DVBViewer i can adjust so it run smoother? I use Nividia graphic card. I use cyberbase 10, and the hardware acceleration in the DVD power 10 meny. Is it suppoused to be on or off. And the what is the correct value on the Latency and the Max Queued Audio?? And what are we adjusting with tthat setting? Quote
themaster1 Posted December 31, 2011 Posted December 31, 2011 Forget cyberlink codec, use Arcsoft codec (version 2.27.432) , you can get it in total media theatre 5.I have made tests with cyberlink pdvd10), Coreavc v2, v3 and Arcoft v2.27 win by a mile. Quote
