Ducatirider Posted December 30, 2011 Posted December 30, 2011 (edited) Hi guys. I've just upgraded my machine from Vista 64bit too 7 64bit and did a fresh instal of DVBViewer. I have done a channel search, no problem yet when I click to view a channel the program freezes and then closes. What could be the problem????? Do I have to get a win7 64bit version ??? Edited December 30, 2011 by Ducatirider Quote
QBox User Posted December 31, 2011 Posted December 31, 2011 Codecs will be different. If you used same Setup file, reconfigure. Microsoft codecs are fine, except for AC3. Also change renderer to EVR, custom. Quote
Gofler Posted December 31, 2011 Posted December 31, 2011 You just opened your windows to let Bill in, so it's up to him. Sorry I'm joking, but there's no 64-version of DVBViewer on the market, wherefore. There are plenty of informationes here in the forum, gates and doors are open 24/24. Just try. Happy new year Yours faithfully Sofy Quote
Ducatirider Posted January 1, 2012 Author Posted January 1, 2012 Codecs will be different. If you used same Setup file, reconfigure. Microsoft codecs are fine, except for AC3. Also change renderer to EVR, custom. Problem sorted thanks, just changed the codecs and it works fine. Quote
