How do I change the MiniEPG timeout on channel change?
aos
Hi all. I've looked all over the place for the answer to what seems like a pretty simple question, but I can't find any help...
I like that the MiniEPG pops up at the bottom of the screen on channel changes, but the timeout is *way* too short for me. Must be some real speed readers out there. :) It appears and disappears in around two seconds. I can't read this fast!
Adjusting the OSD menu timeout doesn't change it. An old changelog says MiniEPG timeout is the same as OSD timeout, but there doesn't seem to be any such option, either in the GUI or in the xml files.
I really just want the MiniEPG to display for five seconds or so when I change channels so I actually have time to read the synopsis of the program.
Thanks if anyone can shed some light on this.
-andrew
Argh! Thanks Tjod. Somehow I completely missed that bunch of EPG settings. I feel dumb now. :) Thanks for the pointer!
-andrew
