RS 1.9.3.0 can't stream
horndrup
Just installed the RS 1.9.3.0 and I have problems with streaming. I can stream recordings fine, but not live tv.
svcdebug.log
04.01.12 14:54:55.872 Checkdevices Sending retune to WinTV HVR-930C DVBC Tuner (2)
04.01.12 14:55:00.943 Checkdevices Sending retune to WinTV HVR-930C DVBC Tuner (2)
Please try the manual device search in the configuration program -> hardware. There are quite some changes in the hardware area, you might have to do the search.
Got it working, by setting af checkmark in "Force Auto Modulation" under Hardware. But what does this option do ?
hmm maybe I forgot this in the changelog. :(
from grigas transedit changelog:
- Added: Settings -> Hardware -> Force Auto-Modulation (only for EMPIA-based DVB-C tuners like Hauppauge WinTV HVR 930C, TerraTec Cinergy HTC XS, TerraTec H5, Pinnacle PCTV Quatro 510e, Elgato EyeTV Hybrid, MSI Digivox Trio).
If this checkbox is ticked, TransEdit lets the driver detect the modulation, regardless of the modulation (QAM16...QAM256) set in the TransEdit Main Window. Change this setting if tuning does not work reliably.
This applies to the RS also.
