Cinergy S2 CI problem
HI!
I have Terratec Cinergy S2 CI PCI tuner, W7 X64, Cinergy driver 1.01.02.501, DVBViewer 4.9.0.0.
Problem is, DVBViewer found my tuner but when i try to scan channels is says no hardware available.
Any help?
A other program eg. WMC is using this card at the moment.
Can't find sollution. Even USB DVBT stick won't tune any channels. Same error.
I format my drive and reinstalling everything, still same problem.
Did you install Terratec software ? Do you have recording service ? Check windows services, maybe some other services like TVService or something like this is using your card, disable WMC and Media sharing in Windows, when try again.
  • 5 weeks later...
Here is support file.
Even USB-T stick won't work. Same problem, DVBViewer found hardware, but same error when try to search channels.
Edited by Jarno
