dotdkay Posted January 8, 2012 Posted January 8, 2012 Hi, When I save the teletext as an image, I give it a filename, but it seams like DVBViewer appends something to the filename. If I choose to save my files as 3plus.png, the filename becomes: 3plus 100 (2).png Is there anyway to have DVBViewer save it as the filename I choose without appending different stuff to the file name. I get that 100 refers to the pagenumber, but the number in brackets I have no idea what that's refering to. And it's not because I have more files named the same in the folder, it's the only file in the folder where I'm saving. Hope that somebody in here can help me. Quote
Gioxy Posted January 8, 2012 Posted January 8, 2012 Hi dotdkay, as you certainly know teletext can have subpages, so the number in brackets simply is the subpage number... Quote
dotdkay Posted January 8, 2012 Author Posted January 8, 2012 Ah, of course yes, thanks I just thought it was refering to the total amount of subpages, but it's the current. But are there any way to get rid of the appended text to the filename? Quote
