Howto make keyboard shortcut for plugin ?
how to make a keyboard/remote shortcut to the neutrino channel list plugin ?
Thanks.
i've finally found a solution to have neutrino cl plugin on a remote button with this guide:
1> add this line in bottom of actions.ini in DVBViewer folder
NeutrinoCL = 20480
2> in the DVBViewer options under "Input" add a new group called ActionScript
3> in this group with "Add" to create a new action, habs "NeutrinoCL" called.
After you have typed the name popt the window with the actions, select the drop-down list (In my case NeutrinoCl), then click Add, click OK.
4> create a file called command.vbs in subfolder "scripts" of DVBViewer folder with this:
sub main (ActionID)
Select Case ActionID
Case 20480
WindowManager.ShowWindow (268435440)
End Select
end sub
5> DVBViewer and start enjoying :)
PS: Many many thanks to the guys helps to do this !
