lruneh Posted January 10, 2012 Posted January 10, 2012 Hi all I've recently installed DVBViewer pro on my win7 x64 system. I have a cinergy dvb-c pci card for tuner. When I scan for channels, DVBViewer shows a strong signal, but it finds no channels. I had the demo installed, which found the channels alright, but after installing the pro version, I get no channels. Any help? It would be much appriciated. Best regards and thanks Lasse Hansen Denmark Quote
Tjod Posted January 10, 2012 Posted January 10, 2012 Try Options > Hardware > force auto modulation. Quote
Griga Posted January 10, 2012 Posted January 10, 2012 Try Options > Hardware > force auto modulation. ...only available for USB DVB-C tuners, not for PCI. Quote
lruneh Posted January 10, 2012 Author Posted January 10, 2012 Hey guys thanks for the suggestion. it's really wierd with the strong signal - there must be something I can do? Quote
lruneh Posted January 12, 2012 Author Posted January 12, 2012 JUst found out I need to attach the support file, so here it is. I really hope I can get some support for ths. Thankssupport.zip Quote
lruneh Posted January 12, 2012 Author Posted January 12, 2012 Hey qbox No, i haven't tried transedit, but will look into it right away. Thanks for the reply, btw Quote
lruneh Posted January 13, 2012 Author Posted January 13, 2012 Tried transedit, but got nothing. Any suggestions anyone? Quote
QBox User Posted January 15, 2012 Posted January 15, 2012 Which frequency file are you using to scan? I don't know what the correct one is for cable, but this post might help: Cable Denmark There's a .ini file attached which may be suitable. I've seen another link that mentions 6875 for symbol rate rather than 6900. Quote
lruneh Posted January 16, 2012 Author Posted January 16, 2012 I'm using the yousee cable transponder list. That's th one the worked initially. I know I need to search with the following settings: network id 100, qam64, symbol rate 6875. I've tried the file you suggested, just for good measure, but no good... Could it be tht i have a strong but distorted signal? Quote
QBox User Posted January 16, 2012 Posted January 16, 2012 Cable is new to me, but there are other posts on the forum that might help. http://www.DVBViewer.tv/forum/topic/42594-frequencies-without-patpmtsdt/ The last post suggests that the Network Information Table is sent on only one transponder - the first? Posts on other forums suggest you may need to scan 143000 kHz to get updated information. I guess that your network will only use some of the 106 possible transponders listed in the file. Use TransEdit "Analyse" function on 143000 and "Update" if it seems to contain a NIT. Otherwise, I would suggest retrieving the transponder file you used to scan the Demo version. Copy that to the DVBViewer Transponder folder and scan. Quote
webmaher Posted January 17, 2012 Posted January 17, 2012 Try search with TransEdit and use QAM 256, SR 6875 and frequency 110-862MHz Quote
QBox User Posted January 17, 2012 Posted January 17, 2012 This very useful document provides technical information on the Yousee system The Rules of Operation for YouSee Digital Cable TV Networks in Denmark From section 7: As the total network topology can be extracted from the Homing channel, fast CPE channel searchand installation can be achieved. The CPE only needs the below listed figures to perform the complete channel installation without tuning to other QAM channels. 5 NIT other tables each designated different groups of CPE equipment are broadcasted in the network: Homing channel tuning parameters: 1. QAM Frequency, default value: 143.000 MHz 2. Symbol rate, default value: 6,8750 MS/s 3. Modulation: default value: QAM64 QAM256 is also used in the system, so the list may be out of date. An update on the homing channel might adjust it. Frequency range: 110 to 862 MHz, from Q1 2011 extended to 1002 MHz The system can't have more than 80 streams, so the 106 frequencies won't all be in use. It's possible some are carrying analogue services, so you would see a signal but wouldn't be able to detect DVB services. Quote
lruneh Posted January 17, 2012 Author Posted January 17, 2012 Thanks to Qbox user and webmaher i'll look into your suggestions as soon as I get home from work. Quote
SimonP Posted January 17, 2012 Posted January 17, 2012 If all else fails, perhaps it's worth trying a full uninstall/reinstall? It's just possible that something went wrong with the original installation. Quote
lruneh Posted January 18, 2012 Author Posted January 18, 2012 (edited) Hi SimonP Been there, done that - several times Could this be a decoding problem? My provider, Yousee Denmark, recently changed to mpeg-4. I only see that my Terratec cinergy dvb-c pci hd card supports mpeg-2 - could this be my problem? Would DVBViewer not be able to find any channels, if I didn't have the correct codecs installed, or if they were incorrectly configured? Or would it find them and simply not be able to show them properly? Thanks for the help and suggestions, everybode. I really appreciate it **EDIT** To webmeher and qbox user: Tried your suggestions, but no dice, I'm afraid. Edited January 18, 2012 by lruneh Quote
QBox User Posted January 18, 2012 Posted January 18, 2012 Codecs don't affect scanning. What happens when you select freq. 143 in TransEdit and click "Analyze"? Quote
lruneh Posted January 18, 2012 Author Posted January 18, 2012 When I click analyze, I get nothing. Quote
QBox User Posted January 18, 2012 Posted January 18, 2012 No Analyzer window or just "0" for Data rate and Signal Quality? Is the device detected correctly in Settings-Hardware? Can you try the card/driver in another application? I think your system file listed Windows Media Center. Quote
lruneh Posted January 18, 2012 Author Posted January 18, 2012 I get the analyzer window, but it doesn't find anything, so "0". I've tried with dvbLink, which also reads a strong signal and even a good quality. It yelds the same result. I have also tried the terratec home theatre (which is awful - even when it works) and it also cannot find anything. i'm beginning to consider a complete reinstall of windows. it just occured to me, that just before it all stopped working, I had to install DirectX and , I think, Silverlight. Could this in anyway interfere? Quote
QBox User Posted January 18, 2012 Posted January 18, 2012 Instead of reinstalling, you could restore system to when it worked. I had to do that recently when another application update messed up video playback. Save the settings from the Demo version - especially channels.dat - and compare them with the Pro settings. Quote
lruneh Posted January 21, 2012 Author Posted January 21, 2012 Got it working now! I went through th cables to make sure they were alright. Turns out the signal was rubbish due to bad cables. Anyway / thanks a lot for trying to help. Im now enjoying this great software! Thanks again. Quote
