TBS 6928 & Jolly 1.01 CAM
Nicholas Carlson
I have the TBS 6928 with a Jolly 1.01 CAM, driver v1.0.0.5. I use DVBViewer Pro v4.9.0.0. I am having trouble viewing encrypted channels correctly in the DVBViewer program: it works once after PC startup, but if I restart the program or switch users, I can no longer view encrypted channels. Additionalywhen I use the DVBViewer Recording Service, the channels only record properly when I have the channel tuned in the DVBViewer program. Otherwise, if the DVBViewer program is closed but the Recording Service tries to record an encrypted channel, the channel is not decrypted by the CAM and is thus not recorded properly.
It seems that the DVBViewer Recording Service does not know how to activate the CAM in the TBS 6928, but only in the DVBViewer program (and that only rarely).
I have another computer configured with a FloppyDTV-S2 with the Jolly CAM. The DVBViewer Recording Service works perfectly with it, so I know that this is a problem that can be solved.
I have a Sky (Italia) TV card. My PC runs on Intel core i7 x58 chipset, with the NVIDIA GeForce GTS 450, driver v8.17.12.6089.
Can you help? Maybe I don’t have the DLL installed correctly? Thanks.
