TonyKeogh Posted January 11, 2012 Posted January 11, 2012 Hi. I use DVBViewer with an Avermedia DVBt/DVBs card to receive UK Freesat channels from Astra and the new Irish DTT service. I've been using it since about June 2010 with no problems and delighted with the program. The Irish EPG has always been a bit flaky with some gaps within listings and listings of less than seven days but that problem may be at the source end because others have reported the same on set-top receivers. I used tune to ITV HD to collect the Freesat EPG data and this always worked fine, collecting a full seven days EPG. However, sometime in 2011 the DVBs and DVBt EPGs both started only showing one day's programmes instead of seven. I've searched the forum and googled to try to find what to do to correct this but without success. I'd be very grateful if you can tell me what to do. Thankyou. Support detail file attached... support.zip Quote
TonyKeogh Posted January 11, 2012 Author Posted January 11, 2012 Discovered the problem - mea culpa! The DVBViewer window has a filter button at the bottom. Somehow it had got set to "Now". Changing it to "All" showed up the full EPG. Quote
