Knut Posted January 13, 2012 Posted January 13, 2012 Hi, I have a HTPC with DVBViewer and card from digital devices. I wounder what the correct frequence adjustment on my pc/htpc should be, when waching ordinary TV. Is it 23, 24, 50, 59 or 60Hz i should use? Or something else? I have a Samsung LED TV. UE60D8005. I wounder about that because my picture looks very good, bu looks like is is not running smooth or som kind og jogging. Not much, but i can see it. Some information you may not need: Im located in Norway, and electrical power in Norway is 230V 50Hz. Quote
mague Posted January 13, 2012 Posted January 13, 2012 The same as the TV station uses. Acording to http://countrycode.org/tv-standards its 50 Hz in Norway. Quote
