jmetsako Posted January 16, 2012 Posted January 16, 2012 I have question about :8089/iphone streaming. If I use iPhone web interface with my windows phone 7.5 mobile browser, everything else works nice but steaming complaints about flash. That's pretty oblivious since wp7.5 does not support flash. Browser details from www.mybrowserinfo.com: -> Mozilla/5.0 (compatible; MSIE 9.0; Windows Phone OS 7.5; Trident/5.0; IEMobile/9.0; Nokia; Lumia 800) Is there way to ignore browser detection with recording service? I would like to see is my phone capable to receive iPhone compliant stream. Best regards Jani
Lars_MQ Posted January 16, 2012 Posted January 16, 2012 The iPhone streams only work for apple devices. It's a special format which your windows phone won't handle.
Ulf Posted January 18, 2012 Posted January 18, 2012 The iPhone streams only work for apple devices. That's not entirely true. I have a Samsung Galaxy Nexus (Android) phone. Version 1.9.3 works just fine, but I have downgraded to version 1.8.0.1 that gives me the possibility to stream directly to the phone without reencoding by ffmpeg. I have MX Video Player installed on the phone that can connect to a network stream. Not automatically though, one has to manually input the IP and port number. With the MX Video Player one can for instance easily adjust the screen brightness - not possible with the Flowplayer. I would appreciate an option to reencode or stream directly in a coming version of DVBViewer Recording Service. One drawback of version 1.8.0.1 is that setting a recording doesn't work (works in version 1.9.3).
janip Posted January 19, 2012 Posted January 19, 2012 That's not entirely true. I have a Samsung Galaxy Nexus (Android) phone. Version 1.9.3 works just fine, but I have downgraded to version 1.8.0.1 that gives me the possibility to stream directly to the phone without reencoding by ffmpeg. I have MX Video Player installed on the phone that can connect to a network stream. Not automatically though, one has to manually input the IP and port number. With the MX Video Player one can for instance easily adjust the screen brightness - not possible with the Flowplayer. I would appreciate an option to reencode or stream directly in a coming version of DVBViewer Recording Service. One drawback of version 1.8.0.1 is that setting a recording doesn't work (works in version 1.9.3). There is same old vlc streamer in new rec service, just klick "Old streaming method"
AlexGml Posted April 5, 2012 Posted April 5, 2012 Where is option "Old streaming method"? I can't find it. Thanks
AlexGml Posted April 7, 2012 Posted April 7, 2012 found it in web interface , by mistake expected to see it in the iphone version
clashcityrocker Posted April 21, 2012 Posted April 21, 2012 Really needs to support Android devices, now iPhone is a marginalized minority device.
jmetsako Posted July 13, 2012 Author Posted July 13, 2012 Has anyone been able to find working VLC transcode settings to stream windows phone 7.5? regards Jani
